N2724G RV9 Build Log
Date:  12-9-2007
Brief Description:  Primed Rear Spar Components
Set up center bay in garage to prime parts. Mixed primer and tested on plywood. Sprayed test parts to check compatiblity with MEK as metal cleaner... seems to work just fine. Primed all rear spar components - went very well.
