N2724G RV9 Build Log
Date:  12-23-2007
Number of Hours:  3.50
Brief Description:  Leading Edge Fit & Tank Prep
Removed the bottom skin from the wing and put away. Installed the leading edge section on the main spar, clecoed in place and match drilled holes that connect it to the main spar. Placed left tank skin in leading edge cradle then clecoed the ribs in place.
