N2724G RV9 Build Log
Date:  12-14-2007
Brief Description:  Constructed Right Tiedown
Received the AEX Tiedown part that I messed up a few days ago along with the replacement rib that we had to order from Van's.
Corectly tapped the hole in the AEX stock to accept the tie down eye from Van's. Match drilled the piece to the right main spar then riveted the platenuts to finish the piece.
