Researched gascolator installation. Marked location for and cut out hole in bottom of fuselage for gascolator installation. Upsized holes in dual stick connection rod support bracket for the installation of pivot bushings. Marked dimensions for and drilled rivet mounting holes in control stick support brackets. Upsized and debured rivet holes in LH and RH seat pan. Researched and purchased rod end bearings for dual stick connection tube
