Brief Description: Upper rudder hinge point, landing gear channel, an
The rear fuselage was completed with the mounting of the upper hinge for the rudder. Then the main landing gear channel and lower seat back was cut, drilled and mounted.
The plans tell you to move onto the firewall so I began laying out the firewall with the engine mount holes located and drilled and the front part of the firewall being laid out.
