Brief Description: More work on the bottom rear skin of the fues
After the excitement of receiving the engine, it was back to building. More work on the lower rear fuselage. Angle was attached to the right side and the bulkheads drilled in place. The splice joint was a bit of head scratcher for a bit as the plan is contradicted by building manual again, but I figured it out this time before cutting anything important.
I hope to head back to build for a few more hours tonight.
View of the angle installed at the rear showing the radius. It tapers down to nothing at the splice
