Brief Description: Wing wiring, pitot plumbing, priming and tank work
The stop skins and skeleton were primed. Wiring for the landing and tip lights was pulled. The pitot and AOA tubing was installed. The vent on the tank was filed to shape and the fuel strainer was installed. The nose ribs 1-4 were drilled for grommets for the fuel lines and the wiring for the fuel level sensor
Pitot tubing installed as well as AOA. Pitot mast to be installed prior to closing of wing
Skin primed (as well as ribs), wiring pulled and pitot plumbing done
Grommets for fuel lines and wiring for fuel level sender installed
