Brief Description: Rear ribs located and drilled to the right spar
Major progress today. I drilled the rear ribs to the right wing spar centering them per the plans. Then I used the handy-dandy small profile angle drill attachment I got from Avery Tools to drill the nose rib attachment holes in the angles on the spar.
Rear ribs in place on right wing
Nose rib attachments drilled
The best way to drill the nose rib angle and the ribs to the angle to ensure no damage to the spar
