Paul's Zenith 601-XL
Zodiak 601 XL
Left rear fuse side
Worked on the left rear fuse side. Cut and installed all the L angle and then drilled and clecoed the left rear side to the bottom skin. Diagonal L angles were added in the rear stab support area.
Vertical L angles drilled in place on left
Left side clecoed to bottom skin
Diagonal support L angle in tail section
R-80 Tiger Moth Home
Zodiak 601 XL Home
552
Ailerons
Elevator
Flaps
Preparation
Stabilizer
149
