Brief Description: Left wing lighting and wing tip
Back to work after vacation. The left landing light is completed and installed. Work on the wingtip has begun with the angle strips crimped and the top one drilled in place. The rivet line for the fiberglass tip has been drilled in the nose skin as well.
Fix for mis-drilled nose rib on landing light assembly. Riveted backing plate onto rib
