Brief Description: Work table extention for wing construction
The work table had to be extended from 8ft to 12ft to allow for construction of the wing. I took the chance to re-level the entire table. The joint between the existing surface and the extension were glued together to ensure a smooth transition.
Extention frame
4ft extention included additional storage under the work surface
