Brief Description: 50amp fuse, AOA gauge, wire holding pole, pilot tu
installed 50amp alternator fuse, drilled holes and mounted AOA gauge, installed wire holding pole in the top of the inside of the nose cone, drilled hole and ran pilot tube out of bottom of the nose, drilled and ran outside temp probe
