painted flaperon braket, replaced wire that I was using for EIS wires because the wire I used initially was single strand aluminum (which is not high quality), unwrapped and rewrapped the wire bundle, added in rectifier wire and brought all wires out of the budle at the correct location, attached and riveted flaperon bracket, drilled & clecoed flaperon crank, riveted luggauge platforms into place permanently, attached plexiglass sheets to platform frames
