PATRICK'S WEB SITE
Date:  11-26-2005
Number of Hours:  1.50
Brief Description:  Mounted engine on airframe
With the help of the following people, Ron Willoner, DoubleD, Jimmy Dean, Billy Burgess, Brian (Cindy's fiance), I was able to get the damn engine on its mounts. Not a small task! Be sure that you keep the upper mount losely bolted together. Remove the front of each hose where it attaches to the water pumps (watch the radiator fluid as it will leak out). Have a crowbar, some large screw drivers and a couple of 1x2 pieces of wood.
