PATRICK'S WEB SITE
Date:  1-3-2006
Number of Hours:  7.00
Brief Description:  installed venturi and backup charging wiring
Installed vacuum venturi. .IInstalled led warning light for backup charging system. Installed breaker for backup charging system (should be normally off). Only turn on when primary charging system has failed. The backup charging system is the charge coming from the 18amp generator that is built into the 912's electrical system. The primary charging system will be an external alternator connected to the engine.
