PATRICK'S WEB SITE
Date:  10-3-1999
Number of Hours:  8.00
Brief Description:  Right wing ribs
Drilled out the inboard lower sheeted rib and replaced with the new redesigned rib recently sent from the factory. Installed the outboard lower sheeted rib which required some grinding of the rib to fit it around the already installed rivets that hold the
