Riveted the F873E-1 baggage door rib to the baggage door skin Clecoed and riveted the forward and aft ribs, F873F angle and hinge to baggage door top skin Clecoed the bottom skin onto baggage door and taped baggage door to fuselage Crawled inside fuselage and riveted all but two rivets (that I could not set) Took off baggage door and set two last rivets in bootom skin to forward rib Set rivets in both the inboard and outboard angles. Installed locking pins, bushings, and lock assembly into baggage door
Settin blind rivets in F873D baggage door inner skins
