Clecoed nutplate to intrument sub panels and riveted nutplates in place Cleaned the nutplates with a thread chase Temporarily bolted instrument panel to sub panels per plans to rivet flange Riveted flange to subpanels with the exception of the middle eight rivets Clecoed sub panels into place in fuselage Deburred edges of forward and aft baggage door support strips Installed the WD814 Windscreen support and torqued bolts Removed vinyl from bottom side of forward top skin Removed the sections in the trim detail on F821-1 top skin Clecoed baggage support strips and F821-1 forward top skin onto fuselage
