While aft top skin was drying I started work on the windscreen Final drilled the two 3/16 holes on each side of windscreen that attach to cockpit rails to #12 Temporarily bolted windscreen to fuselage and clamped forward flange to coackpit rail and upper longeron, and drilled #12 the six holes on each side of windscreen. Removed windscreen and deburred parts
Windscreen temorarily in place with two bolts
Clamped in place with one hole drilled and bolt installed and tightened
Right side drilled and bolts inserted for alighnment
