Installed rod end bearings onto the three push rods that control the elevators Final drilled 1/4 inch the holes in both ends of the control column for forward and aft stick Final drilled #12 the rod bearing holes in forward and aft ends of control column Final drilled #12 the holes that attach the F816 aileron pushrod assemblies Filed brass bushings in control sticks to fit Control colum. Marked hole location for retention bolt on rear control stick and final drilled #12, disassembled and deburred. Installed AN313A bolt and final torqued nut Temporarily installed F839 pushrod assembly to mark bolts for trimming to comphensate for minimum allowance in control column tube
Control column and forward and aft sticks installed
install of 839 push tube
Threads on bolt need to be ground back for clearance
