After parts had time to dry, cleaned up the shop and prepared to make final fuselage assembly. Clecoed F843 longerons to F822 forward floor panel. Installed two AN3 screws and four AN3 bolts on each side and torqued bolts nuts to 25 inch pounds per torque chart. Riveted both longerons to F822 forward sloor panel per plans
