Clecoed and riveted the aft Fuselage bulkheads per plans Clecoed the F818 baggage rib angles to F818 L1 and R1 ribs Final drilled #30 common holes in ribs and angles Drilled #40 the holes for the bellcrank and the nutplates on rib angles Countersunk for flush rivets in nutplate positions Deburred and edged parts Trimmed F857 Seatbelt bracket. Edged all the F858 and F857 parts Deburred and edged the F819 Aft deck and the F811 and F810 spacers Edged the lower longerons
