Finished fitting gussets to Center Section. Match drilled Center Section to Mid Cabin braces for nutplates Unclecoed Center Section from forward fuselage. Located armrest, bulkheads, gussets, and rib angles for Fuselagr Side structure. Edged and deburred edges of parts Drilled #40 final size for all nutplates on this section parts per plans Edged and deburred the F823-1 skins. Prepared to make conical bend in aft side of F823-1 skins
first stab at it
Heavier angle and board ripped for 45 degree angle
