Bent the lower longerons and auxillary longerons per plans Studied the plans for proper orientation for upper longerons and bent the four angles/planes bends per plans. Bent the upper longerons per plans Located the F802D -1R and L braces, the F848-1 gussets, the F8456 gussets, and the two F804H-1 mid cabin braces. Created the curve on all parts per plans. Deburred and edged all parts Clecoed the Forward Floor Assembly and the Center Section on a bench and cleacoed together per plans Clecoed the F804H-1 side plates to the center section assembly.
