Clecoed and riveted the two forward bulkheads to the F804A-2 forward center section Clecoed and riveted the K100-8 nutplates to the seat ramp supports and aft floor angles Clecoed all the parts to the F804B-2 aft center section and riveted per plans. Riveted all parts per plans. Installed the two bolts in the F814 seat support ramps and left bottom nuts finger tight per plans
Special Note: Heard back from Vans on the F804G-1 vertical bars. Talked to Ken on 10-28-2013 and he said no problem, just countersink it on the other side and install it. His words "The rivets are nothing more than temproary clecos because once the 1/4 inch bolts are installed, they will do the job." So I'm continueing to build.
Installed the (2) F804G-1 vertical bars. Decided to use all-thread bolts to keep spacing correct between the F804A-2 and B-2 centersection bars
