Installed the elevator bellcrank to pushtube. Attached both elevators to bell crank and torqued the attach bolts. Installed trim tab per plans with longer pin and safety wired in place. Installed the trim cable and adjusted cable by crawling in fuselage and adjusting the attachment points in fuselage for extra slack. Attached trim table cable and made final adjustments
