While fitting the canopy skirts I decided to build up areas under the skirt to make the fit better so I mixed up some resin and silica and built up select areas.
While I had the resin mixed up I put some on the windscreen for the areas I would be glassing in the fairing.
Let that dry and then remasked the inside of the canopy and painted the black strip around border.
