1. Worked on the right side canopy skirt today. Marked, drilled and cleacoed right side canopy skirt in place. I have found that transferring marked lins from fuselage onto canopy skirt really is the easiest way to get hole alignment. Marking and measuring up vertical ribs is the best way i have found to locate holes. I used a very small bit to find hole and then enlarge with #30 2. Unclecoed skirts and trimmed the edges and then recloecoed in place. 3. Took some time to determine how I wanted to connect the two skirts at the rear. I had seen a design on another builders site that I may try.
