1. Spent a couple of hours working on panel light dimmer switch location and install. Connected dimmer to terminal block. 2. Spent time connecting various wires to terminal block, running wires and terminating ends on various instruments. 3. MGL Avionics V6 radio is still on back order but I started connecting wiring harness to terminal block. I purchased a pre-fabed wiring harness for radio but failed to specify that I am seating tandom so the microphone and speaker leads were both short. I will have to splice wire into place to get the length I really need. Urgghh!
Panel dimmer swich installed on left side of sub panel
