Busy time of year but I managed to have an couple of hours to spend so Final torqued motor mount bolts and secured with cotter pins. I ran the #14 wires from Boost Pump to ground and to 10amp breaker on the console. I decided to run the ground up to the ground terminal located near the terminal block located on the cross brace.
