Brief Description: Fitting Horizantial Stabilizer fiberglass tip
I installed the rudder onto the vertical stabilizer and determined the distance needed to trim the fiberglass cap. I cut it down, fitted some styrofoam, mixed up the fiberglass and laid a few layers on top. When it dries I will chip ou the styrofoam and lay a couple of layers inside.
