Tommys RV8 Site
Date:  4-8-2008
Number of Hours:  1.00
Brief Description:  Right Elevator
I had a few minutes today and I fastened the rod end bearings to the right elevator and set them within the 13/16 of an inch to 7/8 of an inch per plans. I will modify my #14 metric wrench later to really get the lock nut set well enough. That pretty much wraps up the right elevator until I get the left one done and check the balance and attacht the fiberglass tip.
Late Note: I went to my buddy Danny's house and bent my #14 wrench and went back home and tightened the locking nut on the rod end bearing. I hung the right elevator on the wall with my other collections and set out the parts for the left elevator and trim tab.
Modified wrench to tighten the lock nut
Measured 13/16 to the center of the rod bearing
Added to the collection
