I took time today to mix up some Body Icing and spread over the top cowling and wet sanded when dried. Between coats and sanding I performed a few other task. The first was to pump up the brakes with Areoshell 5606H fluid. Safety wired plug that replaced the old tachometer. Sanded the air scoop on the lower cowl. Trimmed the back of the scoop and laid up a coat of resin to smooth out the inside. Put second coat of paint on bottom portion of air filter box.
