Had all day today so I was able to make some good headway on the baffling. Cut out the right rear side baffle to fit the engine. Made cut out for fresh air port on bottom right baffle. Prepared and fitted the right side cylinder baffle and attached to engine. Prepared the attach points and made initial fit of both side baffles. Mixed some proseal and glued and riveted the fresh air vent
