Installed the lower cowling for the first time since installing the propeller and spinner back plate. Had to trim some of the baffling material from the front of the lower cowl and cut two relief slots into baffling in the air scoop. Found that the exhaust are now in the way of installing the lower cowl pins at the bottom. Will have to revisit that.
