Clamped pitch servo to the mounting plate. Measured and drilled hole into the elevator control arm and installed the servo control arm to elevator control arm. Fabricated bushings and when I was satisifed with the location of the servo, I drilled the attach holes for the servo. Removed parts for cleaning and deburring, priming/painting. Went home and installed the vinyl lettering on my instrument panel.
