Mixed up several batches of body icing and spread over lower cowl. While it was drying I sanded on air filter box tunnel. Sanded the lower cowling with 220 grit, and sanded and sanded and sanded. After sanding the cowl clean, I test fitted the cowl to the air filter box. One corner required more layups to tak out air gap. removed cowl from airplane and mixed up some resin and layed up several layers on the outside of air intake tunnel
