Finished adjusting the airfilter box and installed the foam block between scoop and airfilter box. Cleaned out the "tunnel" for the scoop-to-filter box. Removed cowling and smoothed tunnel. Layed up three layers of fiberglass, installed the balloon and let set. While things were drying I made the spacers and installed the oil cooler. Installed the fuel pressure sender Installed the oil pressure sender Installed the oil temperature sender. Trimmed ecess baffle material, and placed a bead of high temperature silicone in gaps around baffle. Installed fittings on the fuel injection spider on top of engine. Removed balloon and the layups were dry do I removed the excess foam block and trimmed excess fiberglass cloth.
