I went to the airport this evening and was happy with the top and started drilling and clecoing the top in a few places. The bottom needed a little more sanding and fitting and then I drilled and clecoed the lower part of cowl to bottom hinges. Marked for side cuts and removed bottom half and will trim it on next session.
