Installed seal into vacuum pump gear housing. Assembled new gear and installed vacuum pump gear assembly to engine accessory case. Installed blank over gear assembly since I do not intend on running a vacuum pump. Installed oil screenand bolted oil screen assembly onto case. Installed spring and relief plunger into case just under the oil screen assembly. Installed the new ball and spring and crush washer on oil pressure regulator.
