No pictures today. Just fabricated the angles for the main ribs per plans and clamped in place. Match drilled all holes and disassembled ribs and angles. Match drilled holes from main ribs to angles. Disassembled and deurred and primed angles. Once parts were dry I riveted the angles to the main ribs. Clecoed parts into place and will work on drilling for nutplates and rivet into place in next session and that should finished up this service bulletin.
