I had a little time befre our departure. I set out to rivet the left elevator sub assembly together. I riveted the 703 to the 704 ribs together and then clecoed them to the 702 spar. I had to drill out one of the rivets that fastened the 703 rib to the 702 spar a couple of times and wound up having to use an oeversize rivet. It wasn't pretty but it will be fine. I riveted the 705 rib to the 702 spar and set out on my trip.
The dimpled rivets in the 702 to 702
The 703 rib riveted to the 704 rib
I had to drill on to the rivets that connect the 703 to the 702 spar. Had to drill out for the "opps"
