Tommys RV8 Site
Date:  4-19-2008
Number of Hours:  1.30
Brief Description:  Left Elevator
Today I picked up one inch particle board and cut down some blocks to use in bending the tabs. I used the 705 rib as guide to get the correct taper per inch for the skin. After cutting several different boards for the jigs I place a block inside the skin and matched it with a block on the top of the skin and clamped the entire assembly to the edge of a smooth table. I used a sall block to start the bend and then used the rivet gun and a small block to make the bend smooth. I used the flat rivet set to get the job done. I dont know why but I removed the block and lightly tapped the edges with the rivet set in retrospect I would not have done that because it did create a couple of small dimples that I'm not pleased with. But they will never be seen. I will make sure to only use the small block with the rivert set to avoid this on the trim tab bends.
Left elevator before tabs were bent
Left elevator after tabs were bent
