Today I riveted the stiffeners to the E701-L skin and then set it aside. I detached the E714 counterbalance from the E703, E704, and E713 assembly that I assembled and match drilled on Friday. I attached it the E702 spar. Then I clecoed and match drilled the E705 root rib to the 702 spar. Match drilled the root rib to the spar. I then bent the trailing edge with my break and slid the left elevator sub assembly into place inside the 701 skin. I then clecoed the E606PP spar to the 701 skins and match drilled the E701 skin to the left elevator sub assembly. I will disassemble, and debur, dimple, and prime duringt the next session.
Stiffeners riveted into place on the E701-L skin
E703, E704, E713, and E705 ribs attached to the E702 spar
Left elevator skin clecoed, match drilled to substructure
