No pics today. I went out to the shop this evening and prepared the two fiberglass tips to the rudder. On the bottom tip I cut out the area for the rudder hron and filled to fit then drilled the holes that attach tip to the strips. I will countersink these holes later in the assembly and attach it when I get the light installed and wired in. I did match drill and countersinked and dimpled the top fiberglass tip and skin. once the fit was what I wanted I attached it with the CS4-4 blind rivets.
