MAT ISAs Web Site
Date:  2-23-2008
Number of Hours:  2.50
Manual Reference:  page 11
Brief Description:  Rudder Prep
A piece of sliding tube for the rudder was cut, shaped and fitted at the end of the rudder vertical tube. Adjustments are made to the leading edge before cutting. The top end of the leading edge was than cut and fitted to the top vertical end. Later the bottom was also cut to match the bottom end.
