MAT ISAs Web Site
Date:  3-18-2009
Manual Reference:  Page 3
Brief Description:  Tail wheel spring holder & support
Fitting the tail wheel spring holder to the fuselage with a magnet to see the setup. Still thinking how to hold the holder strongly before tack weld.
Holder support tubing was cut and filed for a good fitting. It was placed temporarily with a magnet. Planning to weld one end of the support tubing to the holder and the other end once the tail wheel spring holder is welded to the vertical tubing. If this is to be done later, the side fuselage tubing may get burnt during welding.
