MAT ISAs Web Site
Date:  3-7-2004
Number of Hours:  5.40
Manual Reference:  page 3
Brief Description:  Alignment of the tail area
Alignment to square off the tail area is tough. In doing so the horizontal tube that carry the aft seat Sta 73 3/8 become dislodge again. After measuring the length (23 1/4"), it was decided to cut another tube. The older tube seem to be too short. The right side fuselage, it seem, was not at the same level to the left fuselage. The right side fuselage is lifted up slowly by using a wooden block until both fuselage is at the same level. Squaring the tail area take a lot of time. Through measuring and using the right angle square ruler , it look ok but feel that it still need further work. (the whole process - 4 hrs) Nevertheless, two horizontal tube are cut but not yet fitted due to the old tack weld. This tack weld need to be trim off so the tube would fit. NOTE: To recheck the squareness of the tail area.
