Alignment to postion the tailwheel spring holder was made by using a rope from stn 0 right up to the last stn ie the tail vertical tube. A line and marking was made on the holder tubing and this was used to align with the rope. The bottom end of the tail vertical tubing was then shaped using a dremel and it took quite awhile to ensure a proper fitting and inline with the rope. The support tube for the holder is measured and this will be cut later on to its proper sizing because it is difficult to hold the holder for a good fitting of the support tubing.
Earlier on marking of the metal tab at both sides of the tail end of the fuselage was made.
