Brief Description: Vertical stab rib & misc metal items
Misc metal item:
i. Cut another piece of the undercarriage metal base (replacing earlier part) ii. Rudder metal disks (x2) iii. Control washer (x2) iv.Fuselage tubing support disks (x4) v. Rudder tubing support disk
Cut the vertical stab rib from .063 metal piece. bent it using the bender and shaping both end to fit the vertical stab.
